Root [MetroPCS] [ROM] Recovery Flash-able Stock M919NUVUAMF2 Rooted/Deodexed [ROM]
ARocker
Android Expert
Please backup your phone before flashing this!
Flash at YOUR own risk!!
I'm not responsible for anything you do to/with your phone.
Code:
[center]
Post One : Rom Information
Post Two : Download
Post Three : Modifications[/center]
ARocker said:
This is a FULL Working Stock M919NUVUAMF2 4.2.2 Rom with nothing removed from it (except for the Modem and MyExtras_TMO.apk) and with only minor added modifications (Rooted, Deodexed, and other stuff).
ARocker said:
I built this Rom to hopefully help kick start a little development for the M919N.
Please use it as a base with which to create Roms and Themes from our own firmware.
Its also great for users who want a fully working rooted and deodexed stock Rom with only minor modifications that you can flash in recovery.
!!!Attention!!!
ARocker said:
I tested this Rom a bunch on my M919N but could use a few more willing testers to confirm that it works as it should.
!!!Attention!!!
ARocker said:
Please be patient and let it boot!! The first boot can take up to 5 minutes, so be patient and wait for it!!
!!!Attention Developers!!!
ARocker said:
All I ask is that you let me know that you're using the Rom and give me credit for the base.
!!!Specifications!!!
Code:
[center]
 Android OS version : 4.2.2
 Model : SGH-M919N
 CSC version : M919NTMBAMF2
 Rooted (Superuser app + su) : YES
 Rooted (unsecured boot.img) : YES
 BusyBox installed : YES
 BusyBox init.d support : YES
 Bash support : YES
 system/framework is deodexed : YES
 system/app is deodexed : YES
[/center]
??Installation Process??
Code:
[center]
-Download ROM, then copy to EXTERNAL SD card
-Boot to recovery
-Factory reset
-Flash ROM
-Reboot
[center][b]Please be patient and let it boot!!
so be patient and wait for it!![/b][/center]
[/center]
!!!Thanks!!!
Thanks to dsixda for his Android Kitchen!
Thanks to lokeshsaini94 for his [GUIDE][how to] CREATE OWN ROM thread!
Thanks to danyvw, techguy1214, exel, dulal18 and anyone else having anything to do with the M919NUVUAMF2.tar that I used to build this!
Thanks to nuttmeg for giving a mirror download location when my DB quit!
Special Thanks to Shabbypenguin for his guidance!
Special Thanks to testers: danyvw, nuttmeg....
Thanks to all of the contributors!
If YOU would like to thank ME for this, you can do so by rating the thread and hitting the THANKS button!
[ROM] Recovery Flashable Stock M919NUVUAMF2 Rooted/Deodexed [ROM]
!!!This Rom is for the MetroPCS Samsung Galaxy S4 SGH-M919N!!!
Download:
Deodexed_Rooted_M919N_MF2.zip
~Mirror~
!!!Addons/Modifications!!!
Nuttmeg has a little thread called Transparent AccuWeather with some great apk mods you'll appreciate.
Be sure and give him a thanks.
Also check out [Xposed (Xposed Framework)] - [ROM modding without modifying APKs by rovo89]
There is also a volume boosting mod that works with this Rom, posted and tested by danyvw [MOD] Volume Boosting Sound.
Be sure and give him a thanks too.
The Note 2 Hidden Settings app by SteinApps, does exactly what you'd expect: it offers access to otherwise hidden system settings in the Note 2 and the S4. Its also free!
!!!Themes!!!
None Yet
Fixed systemui/frameworkres
Downloaded, (took almost 2 hours) Installed, booted in around 4 minutes. Installing my apps and debloating right now, for the moment everything is working flawlessly.
Yea, the download is slow and the file is a big one. Leme know how it works out for you. Thanks for testing :)
WOW how did I miss this? Great work bro...When I have a little time on my hands I will try to make a theme for us hopefully. The S4 has so many things to port...lol but with Wanam this rom can be theme like crazy, but once again thank you very much. :D
Ive got a proper debloated Rom in the works called MetropolitanS4. Id like to hook it up a bit with goodies like 4 way reboot and volume track skip before I release it but ive run into a nasty snag. If you've read this thread in our sub forum, you'll know that there are issues compiling apks with the S4 variants. In short, that means until that issue is sorted out, there aren't going to be any mods done in the traditional decompile, edit, recompile method and also some themeing requiring code edits cant be done until we try to implement the proposed workarounds. The good news is that once the workaround is done, we can post the "fixed" apks so that there wont be an issue going forward and also in the mean time we thankfully have Xposed and Wanam to fall back on :)
I had a major problem with the TW framework :mad:
Did you get it to compile? I get the same errors every time when compiling framework (even when I make no edits) with three different apk apps. I read that a few of the apks are effected by this including the two most important, systemui and frameworkres.
|Sun 10/13/2013 -- 1:51:45.47|
java version "1.7.0_21"
Java(TM) SE Runtime Environment (build 1.7.0_21-b11)
Java HotSpot(TM) 64-Bit Server VM (build 23.21-b01, mixed mode)
|Tue 10/15/2013 -- 6:32:02.21|
|Thu 10/17/2013 -- 11:45:53.32|
The system cannot find the file C:\APK-Multi-Tool-Experimental-RELEASE\projects/None.
I: Loading resource table...
I: Loaded.
I: Decoding AndroidManifest.xml with resources...
I: Regular manifest package...
I: Decoding file-resources...
I: Decoding values */* XMLs...
I: Done.
I: Copying assets and libs...
W: Could not find sources
I: Checking whether resources has changed...
I: Building resources...
C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res\layout\keyguard_screen_password_landscape.xml:22: error: Error: No resource found that matches the given name (at 'layout' with value '@layout/keyguard_transport_control').
C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res\layout\keyguard_screen_password_portrait.xml:22: error: Error: No resource found that matches the given name (at 'layout' with value '@layout/keyguard_transport_control').
C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res\layout\keyguard_screen_tab_unlock.xml:23: error: Error: No resource found that matches the given name (at 'layout' with value '@layout/keyguard_transport_control').
C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res\layout\keyguard_screen_tab_unlock_land.xml:17: error: Error: No resource found that matches the given name (at 'layout' with value '@layout/keyguard_transport_control').
C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res\layout\keyguard_screen_unlock_landscape.xml:18: error: Error: No resource found that matches the given name (at 'layout' with value '@layout/keyguard_transport_control').
C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res\layout\keyguard_screen_unlock_portrait.xml:23: error: Error: No resource found that matches the given name (at 'layout' with value '@layout/keyguard_transport_control').
aapt: warning: string 'default_audio_route_name_hdmi' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: en_GB es
aapt: warning: string 'default_permission_group' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: en_GB es
aapt: warning: string 'perms_hide' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: en_GB es
aapt: warning: string 'perms_show_all' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: en_GB es
aapt: warning: string 'ss_clear_default_hint_msg' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: zh_CN zh_HK
aapt: warning: string 'ss_clear_default_hint_msg_all' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: zh_CN zh_HK
aapt: warning: string 'ss_clear_default_hint_msg_applicationmanager' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: zh_CN zh_HK
aapt: warning: string 'ss_clear_default_hint_msg_more' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: zh_CN zh_HK
aapt: warning: string 'ss_clear_default_hint_msg_settings' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: zh_CN zh_HK
aapt: warning: string 'tommorrow' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: bn_IN
aapt: warning: string 'webkit_module' has no default translation in C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res; found: de es_ES fr it pl ru
Exception in thread "main" brut.androlib.AndrolibException: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 17, -F, C:\Users\ARocker\AppData\Local\Temp\APKTOOL8080593555093530560.tmp, -x, -0, arsc, -S, C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res, -M, C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\AndroidManifest.xml]
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:353)
at brut.androlib.Androlib.buildResources(Androlib.java:281)
at brut.androlib.Androlib.build(Androlib.java:209)
at brut.androlib.Androlib.build(Androlib.java:177)
at brut.apktool.Main.cmdBuild(Main.java:237)
at brut.apktool.Main.main(Main.java:79)
Caused by: brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 17, -F, C:\Users\ARocker\AppData\Local\Temp\APKTOOL8080593555093530560.tmp, -x, -0, arsc, -S, C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res, -M, C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\AndroidManifest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:406)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:334)
... 5 more
Caused by: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 17, --target-sdk-version, 17, -F, C:\Users\ARocker\AppData\Local\Temp\APKTOOL8080593555093530560.tmp, -x, -0, arsc, -S, C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\res, -M, C:\APK-Multi-Tool-Experimental-RELEASE\projects\framework-res.apk\AndroidManifest.xml]
at brut.util.OS.exec(OS.java:89)
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:404)
... 6 more
The system cannot find the path specified.
I plan on trying the workaround this weekend, maybe sunday.
http://forum.xda-developers.com/showthread.php?t=2264380
I: Loaded.
I: Done.
... 5 more
... 6 more
Error compile apk [problem partially solved] - xda-developers
Same errors, and just decompile and recompile without touch anything and bammmm here comes the error.
If it's ok with you, I can mirror your link just incase your link generate to much traffic and DB put you on hold and we will have a backup link going.
so far so good and no issues, using theme dailer, mms, contacts and 5x6 app drawer. Next i'm going to try vr-theme and see how it plays along with our stock rom.
Here running good too. No theme but with many Exposed framework mods with Wanam Xposed and Xblast Tools, clear weather widget and increase volume mods too.
Wanam is great and been using it for sometime now, but I know you would love the 5x6 Launcher to go with that package. ;)
Yea man, thats cool. I was thinking of posting this over at xda too, with a link back to here to download so a mirror would be appreciated :)
Awesome, glad to hear it!! Thats the setup up im using for the MetropolitanS4 Rom im working on lol. Prolly have that up in a few days.
Thanks Nuttmeg :)
Pleasure ARocker. Thanks to you and nuttmeg for starting the SGH-M919N development with this ROM and mods.
Thanks to you too for fixing the odin tar this rom was built from :)
Im hoping that posting this rom at xda will bring back the Metro peeps we lost to the Tmobile ROMs and also maybe those Tmo devs will want to make Metro versions of their roms (prolly not, but who knows).
