Root [MetroPCS & T-Mobile] ROM in different model
Hi all! This is my first post. Sorry for any orthographic error, I'm Brazilian and I use a little help from Google Translator.
I have the LG Optimus F3 P655H (I think that this version only exist here in Brazil) and I want to install a custom rom. But, I only found custom roms for american's carriers with differents models, like MS659, LS720 (correct me if I'm wrong), etc, and I'm afraid to install these roms in my phone (model P655H from the brazilian carrier "Vivo"). What problem could have? I can't find any help about this.
I already tried to change LGSystemUI.apk and didn't work, maybe because of the model that I have (or even wrong installation): [MOD][LGSystemUi]Remove QSlide apps Deodexed v5, v6, & v7
I'm crazy to install this rom, but as I already told, I'm afraid: [ROM][MS659 & P659] Xperion ROM *Updated 9/20/14*
So, what problem could have? And if the phone doesn't boot after all?!
I don't need any rom, but I only want one.
Thank you for the patience.
The mods & roms you find here are carrier specific. They will not work properly for a p655h f3 variant. Sorry. :(
I have just installed and is working perfectly.
Does not have the Portuguese language but I will see better sometime, no problem.
The signal works perfectly and it is possible to make calls.
I installed the CWM Touch Recovery and then install the rom from zip.
