Root [MetroPCS] Tether working but not the PS3 and PS4 Help please.
1Hunnit
I got the tether working on my f6 but its not working with my PS4 could someone help me with this please? Just upgraded from my lg connect 4g tether worked fine with the ps4. I just had to switch it to cdma first before switching it back to 4g. The f6 using wcdma so its not working I keep getting a error code.
The PS3 and PS4 both need ports forwarded through the router (which a tether is) in order to work. If your tether app can't forward ports ((and since most carriers won't allow you to use a server, probably none of them can), the PS3 and PS4 won't work through a tethered connection.
Check Port Forwarding Ports List - PortForward.com for the ports you need to forward. (BTW, since the PS3 and PS4 have a port in common, you couldn't use both of them at the same time even if you could forward ports, because you can't forward the same port to 2 devices.)
