Root [MetroPCS] usb mass storage mode
dcap0187
am i missing something. just bought the gs4 and can not connect via usb to transfer files.?.?
Hi here to help. it sounds like you need to install samung drivers on your pc. or sometimes you can get a bad usb cable. one other thing to try is a different usb port on your computer. hope this helps.
thanks i've tried multiple cables and different computers. reinstalled drivers. the only fix was a factory reset.
i never had this happen i thought it was the phone from the get go. i have a gs3 i gave to my wife. and its worked fine.
i'm not that much of a noob even though if you read my problem you would of thought so.
