Help MHL-Adapter for Ace
insekticide
Hi Guys,
has anyone tried an MHL-Adapter for their ace yet? If yes, does it work. For those who dont know, here is what i mean.
Bei AMZN ansehen:
Samsung HDTV zu HDMI Adapterkabel (EIA2UHUN) z.B. für Samsung Galaxy S2
http://www.amazon.de/dp/B0051D3KQW/ref=cm_sw_r_an_am_ap_am_de?ie=UTF8
Thx.
Insekt
No... but it looks pretty cool from the description of the one at Amazon USA:
http://www.amazon.com/Samsung-Genuine-Original-Adapter-TV-Out/dp/B005CLF8FE/ref=sr_1_2?ie=UTF8&qid=1335715243&sr=8-2
Product Description
This MHL adapter allows you to view your favorite videos, movies, music, photos and other media on your phone on a compatible HDTV. Simply connect a universal HDMI cable (not included) into the MHL adapter and your HDTV. Then connect the travel charger included in your phone into the side of the MHL adapter. Make sure your travel charger is connected to a power source. Then connect the MGL adapter into the micro USB port of your phone and select the appropriate HDMI port on your TV.
MHL specification version 1.0 is an HD video and digital audio interface for connecting mobile phones and portable devices to HDTVs and other home entertainment products. It utilizes established connectors and features a single cable with a 5-pin interface, supports 1080p HD video and digital audio, and simultaneously provides power to the mobile device. It also enables the TV remote to control the mobile phone and access its contents.
Note: Do not connect the MHL Adapter to your device through the Desktop dock. The Video and Audio output will not work correctly.
Note: Any incoming calls or messages will pause the media output. After taking the calls or acknowledging the messages, the media will resume playing.
Note: If your TV has multiple HDMI ports, you may use any of the ports but need to make sure your TV settings have the correct HDMI port selected. Consult your TV owner's manual.
Note: After connecting the MHL Adapter, the upper and lower sides of the TV/Monitor's screen may be cut off. In this case, you can adjust the TV/ Monitor in the Settings menu on your TV. Consult your TV owner's manual.
