ayush20m
I was having a lot of trouble finding a solution to this problem and also applying the solution. I had to run from one forum to another to fit everything like it should. Since a lot of MT3G users use SuperD, here is consolidated guide to help solve your mic issues, till they are fixed by the devs.
Step1:
Download and install android sdk from here.
If you are having trouble installing the sdk, here is a complete guide for installing and using sdk.
Step2:
Download this file. Unzip it and save it in your c:\ drive (not in any folder)
http://www.mediafire.com/?nwxomlgymfy
then adb:
adb remount
adb push c:\AudioPreProcess.csv /system/etc
adb push c:\AudioPara4.csv /system/etc
adb push c:\AudioFilter.csv /system/etc
adb shell reboot
Step1:
Step2:
then adb:
adb remount
adb shell reboot
