Does anyone know if there is a way of turning down camcorder mic volume or a app that can adjust this?
Hi all i've had my dhd for two days now and am impressed with it ( previous phone i8910 ) Hd recording is ok ish but heard there is a update coming but must say the mic recording volume is VERY poor how can you turn it up? as its way to low and tinny. Is this normal or should i ask for a replacement?
Cheers i was beginning to think i had a duff HTC. Just 1 more thing i find the HD recording not smooth compared to my i8910, is this normal too as the main reason i got the dhd was for better HD recording, if so am right thinking that the next update will sort it out?? my software is 1.32 & android vers 2.2 btw according to tmobile my dhd is upto date.
yeah the next update, which is 1.72, totally removes the jitter you get with your firmware version.
The reason why yours tell you you are on the latest is because apparently HTC have pulled the update (or at least its believed) because of other problems its brings like an sms bug. Another possible reason is because T-Mobile havent made the update available yet for your phone. Either way you should get it soon so i wouldn't worry about it mate.
(had same prob with i8910 had to flash) well guess me and many others will just have to sit and wait for this update
thanks mate you have put my mind at ease....it was really doing my head in. Just dont understand why they dont sort out these issues before releasing these flagship phones(had same prob with i8910 had to flash) well guess me and many others will just have to sit and wait for this update
well dont know too much about rooting but i do want to get the most out of the dhd...mean like shall i wait for the update 1st or can i start rooting now? will it void my warranty? and if i do root can i still update via my network? sorry but android is new to me![]()
just take things slow and you'll reap the rewards. Head over to xda and you'll be on your way
