My mic works when recording video only. It isn't working for phone...speakerphone or not....or Okay Google or even recording. I have wiped and reflashed with various ROMs and still no luck. I haven't tried going back to stock yet.
Anyone else had this issue before?
Thanks
Get a new charge board and make sure the coaxial cable is touching the clip that holds it to the board on the bare spot of the cord. That happen to me and I got partial sound by wiping the cash and reinstalling factory os yet it quit again and I would have to restart phone. It wouldn't even have sound or mic using headphones. I got a new board and that did it. Also I found reading other forums that the non-holis file for the modem will fix it. The only software I know of that will properly fix it is UNI. ITS $50 a year.
I was flashing ROMS that had worked in the past like Discord 1.1 and Lineage 14.1 doing full wipes.
I had done a full backup of stock in TWRP. I had heard these backups don't work if you didn't clear the cache first before creation. That's kind of true. My backup wouldn't restore so I deleted 3 cache files in my backup folder and tried to restore and it worked.
After getting back to stock I tested my mic and it is working normally again.
I am back on Discord 1.1 and rooted and its all back to normal.
Thanks for the input everyone!
