Hi.
I've both the Tasker and that MicoPacks plugin installed on my Huawei Mate 9 phone.
I have about 50 icon packs installed on my phone.
I know that I can use that plugin to auto change the icon packs at a specified intervals.
But with 50 icon packs installed it seems so impractical to do so, adding task one by one.
So is it possible for your team to modify that MicoPacks plugin so that it can be set to randomized all the installed icon packs automatically rather than needing it to be added one by one.
Appreciate your feedback a.s.a.p
Thank you.
Thank you.
