Micro SD card class compatible
bonjb
Hello again,
What micro SD card class is the SGY compatible with? I realized it late that my 'unexpectedly removed SD card' problem might be linked with this. I bought a Kingston 4GB Class 4 SD card to replace my 1GB Kingmax SD card (no class indicated on the card so I can't determine). :(
Class shouldn't matter. SD card classes only describe the read/write speeds the card is capable of, not compatibility.
hi sorry about using this topic...
whats the max capacity the samsung galaxy y GT-S5360B can use?
i mean, if i buy a 32GB mini sd card it will work as good as the 2GB that came with?
thx.
