Micro SD caused freeze ups?
gloriousnumber1
Android Expert
I've been seeing some weird stuff happen since I replaced my micro SD card after transferring everything over first. One issue was my phone going from "100%" to "80%" instantly while plugging it in. I did a factory reset and thought it was fine. Then I started seeing my whole phone freeze up while using QuickPic which I use to view pictures (requiring hard reboot due to BSOD). When I was writing a post on Phandroid about that app, it froze up again giving me a BSOD so that I had to hard reboot. Then it even did it at random times and even at boot up. I'm gonna switch my cards back to the old one later tonight and see if that helps. If not I think I'll get a replacement. Anyone heard of this?
I believe you have a bad SD card. When the phone tries to access the data/picture it is causing the phone to freeze.
There are some cheap imitation SD cards that can cause the problem you are experiencing.
