Help micro sdhc card for galaxy mini
hello is transcend 8 GB micro sdhc memory cards are compatible with Samsung galaxy mini?
i am having a problem buying a new one.it has a 2 GB sandisk microsd card with it.but i want to buy a new 8 GB memory card but you all know that android only support fat format so i do not know which card should i choose
please advice me some cards
Hi there,
I have bought a 32gb SDHC card for my Galaxy Mini. Have transferred some music from my laptop onto the SDHC card but am not able to view the albums. I had no issues with the original 2gb sd card.
The files are definitely MP3 format as well.
Any ideas please? Or any step by step instructions would be appreciated.
Thankyou
Can you browse to the files on the SD card when it's in the phone using a file manager like Astro or ES File Explorer? If so, check to make sure there isn't a file called .nomedia in that folder. It will make any media files invisible. If it exists, delete it and restart the phone.
