Micro-USB cable????/?
You dont really need it for a USB cable. All it does is help to get rid of electrical interference, which in the case of usb, it will either work or not.
I ordered the ferrite core / gold plated two weeks ago (the other one was not in stock back then). All six of them worked.
However i found that the micro-USB connection was a notch too "tight" when you compare with the cable provided by HTC. This means you need to be careful when plugging / unplugging the device. Dunno if this could be a problem in the long run though...:confused:
