Micromax A55 FAQ's
Status
Not open for further replies.
D-U-R-X
turbo drinker
This is a work in progress and, as such, if you feel that there is anything that needs adding, please PM a guide or start a thread in Private Chat With Staff with your suggestions.
Many thanks :)
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Micromax A55 Tips & Tricks?
4. What are the known problems with the Micromax A55?
5. Forum related questions.
6. What is root?/What does being rooted mean?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: Smartphones operate on a sort of spectrum. On one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Here are a couple of things that you could consider - adjust the screen brightness, do not use live wallpapers, switch off networks when not in use (WIFI, Bluetooth, GPS), adjust update intervals for widgets (do you really need twitter/facebook notifications every half hour?). You could also consider downloading a battery monitoring app such as JuiceDefender.
Q: Are there any Micromax A55 Tips & Tricks?
Q: What are some of the problems people have with their Micromax A55?
Status
