HolySafari
Hi,
I have a problem with my Patriot signature Line 32 gb microsd card with my rooted 16gb samsung galaxy s3
so i have problem when i try to transfer music directly into the micro sd card from my computer through my phone using a usb cord with the "usb debugging" checked as on.
it always says file is written protected when i try to delete my music or file or cannot copy when i try to copy new music from my music folder on my computer to the microsd folder.
i also tried to use android commander to push it in it also came back as permission denied.
however, i can make changes to the file if i remove the microsd card and insert it into my laptop using the adapter
when i try to change the permission using es file explorer it says that the "write" option on the extsdcard folder is not ticked off but when i do try to check it, it says cannot change.
I also have root explorer installed and tried to toggle the r/o and r/w and it also does not work
the format is already fat32
do i have to reformat it again?
i don't want to have to take out the microsd card everytime i want to add a new song
please help?
please help?
