MicroSD Cards and there Classes
Hi
I just bought a LE Pan Tablet and I am looking to upgrade the SD Card. What class and MFG card should I buy for 32GB ?
Thanks
Welcome to AF :D
You should get at least a class 6 IMO, or a class 10. Class is the min write speed on the card, the higher the class the faster it will write data to the card which means less waiting for you. Class # is MB/sec.
I can't really recommend a specific manufacturer for an SD.
I have a 16 GB class 10 SD Card... Damn fast!
Much more faster than the class 2 I have also at home. Yes, it is expensive, but also worth your money!
