Help MicroSDXC compatible?
8gb is getting a little small for me, I'm going up to 32, and wondering if Rush is microSDXC compatible. The product description for the one I was about to order says not all phones are, and I'm not finding anything on the Google monster that says a definitive yes.
I'm rooted if that matters, but that's about as fancy as I've gotten.
I looked up micro SDXC on the SanDisk site and it said they range from 64GB - 2TB, so I doubt this card can be used on this phone, even though I have never tried. You said you are going up to 32GB which would be SDHC (4GB - 32GB). I have a SanDisk 32GB SDHC card and it runs perfect on my Rush. Thank you for asking this question, as I learned a lot about SD cards that I did not know. Hope this helps. I obtained my information from this site: SD/SDHC/SDXC Specifications and Compatibility. Peace
