Hi. I am an Android user since a year ago, currently owning a Motorola Milestone with 2.1.
I was very excited to know that they will be selling the Milestone 2 in Argentina, but I was surprised that it comes with Motoblur instead of the "stock" Android system.
My brother owns a Quench with Motoblur but I didn't have time to play with it and understand what it does.
I want to know what the general tech-android users consider about Motoblur, which are the pros, cons, if I should try to avoid it, etc.
I like the standard Android launcher (I use LauncherPro for its speed), I want to know if I can change it or if Motoblur won't let me.
My brother told me he had to make a Motoblur account to make the Market app work. Is it that way? Is there anyway to disable the Motoblur thing and keep the phone running the same way as my current Android with my Google Account?
I don't wanna root my phone and use any other android distro, but do you think you'd do that if you owned a Motoblur phone? (to get rid of the Motoblur).
Thanks,
Rodrigo Silvestri
Thanks,
Rodrigo Silvestri
