Fabolous
Superuser
This mod is only for rooted Droids, and there are a lot of adb/terminal commands involved, so it is not for the faint of heart. What it does accomplish though, is well worth the work (IMO). Anyways, I don't think I can post the link, because it is a Milestone port, and therefore not open source, but let's just say you guys can find it. Here are some great instructions, credits to diakonv at Alldroid.
I might add that you can put the audioeffect.zip in the same folder as the modified files, and then:
adb push audioeffect.zip /sdcard/audioeffect.apk
Then, after the reboot after you've modified your audio libraries, install the audioeffect controller.
So far, initial testing has given me great results with the '3' media player. I use a custom effect of 'wide' surround mode and 'bass punch'. Makes my music sound even better through my Dre's.
After some more testing, I've noticed a little hiss in between songs, but it's not a big deal considering the much more noticeable increase in sound quality.
diakonv said:I extracted the modified.zip to a temporary folder on my computer.
I opened a command prompt and changed directories to that temp folder.
In the command prompt I typed:
adb push libaudio.so /sdcard/libaudio.so
adb push libaudioflinger.so /sdcard/libaudioflinger.so
adb push ap_gain.bin /sdcard/ap_gain.bin
then I backed up the originals to my sdcard by typing:
adb shell
su
mount -o remount,rw -t yaffs2 /dev/block/mtdblock4 /system
cp /system/lib/libaudio.so /sdcard/libaudio.so.bak
cp /system/lib/libaudioflinger.so /sdcard/libaudiofingler.so.bak
cp /system/bin/ap_gain.bin /sdcard/ap_gain.bin.bak
then I copied the modified files over:
cat /sdcard/libaudio.so > /system/lib/libaudio.so
cat /sdcard/libaudioflinger.so > /system/lib/libaudioflinger.so
cat /sdcard/ap_gain.bin > /system/bin/ap_gain.bin
mount -o remount,ro -t yaffs2 /dev/block/mtdblock4 /system
reboot
