Mini-USB Synchronization Cable
jamesdal1
I am looking to buy a new Mini-USB Synchronization Cable, where I can I find one? The one on sprint costs 24.99, is there a better place to buy it?
If you have a standard usb mini cable at home use that. Most digital cameras and devices are coming with them these days, and work fine on the Hero despite having a slightly different connector, it still fits and works fine.
Also, check ebay for cables, never let me down yet.
The USB port on the phone is slightly bigger than a normal mini USB in that it has one corner of the plug expanded. There is still one long side and one short side to the plug so a normal mini USB fits in there so long as you align the two longs sides. Having said that, mine is a GSM hero, not sure about sprint...I'm in Canada.
Here is what I bought. Its the exact same thing as what I recieved with the phone. Looks OEM and comes with the wall adapter.
1
OEM HTC Home Charger+USB Sync Cable Sprint HTC Hero - eBay (item 120480441453 end time Jan-11-10 13:56:10 PST)
How do you guys use the mini usb? I have like ten of them form my exclaim and bb's but I cant get them to fit in the hero, the connector looks like like its completly different inside the metal housing?
We have some BB wall chargers and they work. Instead of putting the "face up" mark of the charger facing up, turn it upside down and it fits perfectly. :)
Every HTC device has been like this for a few years. I believe there is an extra pin that carriers audio for HTC's usb headphones etc
