Minimalist widgets
Ricering
I'm looking for some good minimalist widgets for a clean but informative homescreen. A battery indicator consisting of a simple line is the thing I need most atm but I can't seem to find one.
Install Zooper and make one yourself (or download one of the many pre-made examples and edit it to your tastes).
For the thing you want just create an empty Zooper widget, add a "progress bar" to the layout, set it to display the battery level with a min 0, max 100, then fiddle with thickness, colours, etc until it looks the way you want. You can also save the result so you can use it again without having to start from scratch.
Great, thanks man!
Been trying to figure zooper and some other widget customization apps out but could't get them to work. This will probably do the trick
Used zooper and it worked great, thanks! Here's the result (little white line on the right.)
