Root minor issue with eclipse 2.3
alowishus
I installed the eclipse 2.3 rom a few months ago and so far, i love it. However, i've noticed a few bugs. Multiples of the same SMS message from people, random slowdowns, and an odd restart when i leave the flashlight (turned on from the notification bar) on too long. Any suggestions? Should I send these issues to the dev for the next version?
except the sms issue, all are known issues, and have been for awhile
and the sms maybe known, a third party sms app may fix, I've been using handcent with no problems
I highly suggest running with V6 super charger script by zeppelin rox. It works really well with eclipse 2.3 . Make sure to also run the kick ass kernalizer script, the 3g turbo charger, and the nitro lag nullifier. I used to be a huge fan of cm7 but after switching over to eclipse 2.3 , I feel it integrates better with other apps like Facebook, instagram , and dolphin HD. Everything is so much smoother. give that combo a try and you won't be disappointed or laggy.
I too prefer Eclipse over CM7. CM7 may be snappier, but Eclipse is no slowpoke and everything works correctly. CM7 has a couple of issues that, while no deal breaker, puts limits on the X2 that Eclipse doesn't.
same here, I primarily like the fact that the Wifi works more consistently on Eclipse. I miss the customizations of CM7 though.
Are those easy to search for or could you provide me some links?
