pbf98
Android Expert
I have the occasional problem with my pc as I am sure everyone does, and rather than starting a new thread for every time I run into one I thought I'd make a thread that would be for any miscellaneous problems, for anyone.
So if you have problems you can post here and someone can answer it here. This way we can create less threads that have a couple replies that solve the problem.
Anyway my problem today is my computer case fans lights just stopped working, all of them. The fans still spin, but the lights are no longer shining.
Little info on my pc: After I am done using it for the day I will do a proper shut down, and it will stay off until I or my fiancee needs to use it.
The case is a NZXT Phantom, and it does have a fan control on it that is stock (they are little sliders), and from what I can tell they have no affect anymore. Before when you turned it down it would dim the light on the fan that you adjusted, but now it doesn't look as if the fan slows down or speeds up with the adjustment.
Could it be PSU problems? I have a corsair modular 850 watt psu, and everything in the pc is less than a year old
Any ideas?
Thanks for any help
Any ideas?
Thanks for any help
