Apps Missing AVD Dialog Chooser ?
ac4android
Hi.
Usually, when I click Run-> Run 'app', AS gives me an AVD Dialog Chooser from which I can select a virtual device that I've created using the AVD Manager.
It is not doing it anymore and is throwing the Edit Configuration screen instead.
When I go back to the AVD Manager to start an AVD, the AVD just hangs and the cryptic message "emulator: UpdateChecker: skipped version check"
I've just got my Google Maps working after a lot of work on the XML files and the project structure version combinations, I would very much like to get the chooser dialog back in order to start the AVD.
P.S. Gradle build and everything else finished successfully. I was able to runt he app all the way to displaying the Google Maps. My codes could not have caused that.
P.P.S. Aha, I missed the pop-up telling me "Error running app:Unable to obtain debug bridge"
As the error says at the bottom of the dialog, your Android SDK can't be found
In AS select File -> Settings
In the displayed dialog, go to Appearance and Behaviour -> System Settings -> Android SDK
Set the correct path for the Android SDK location
Thanks.
The directory is there, but A/S went and updated the Android SDK and now the app won't display the maps again becaise it is missing "Google Play Services", which I mist have installed x-th number of times
