Missing calendar after software upgrade!!! HELP!
ET Note
I am using Samsung Note and had just upgraded my software (4.1.2). To my dismal, all my calendar appointments gone missing!?! I had used android for more than a year and had never sync with my Mac (Cannot be synced):rolleyes:. Is there anyway I can recover my calendar? This is most frustrating!:mad:
I had just signed in to my gmail to check the calendar, it is also emptied... I too thought that it will be sync automatically..
Check to be sure you have Sync Calendars box checked in settings. If you don't have the "Sync Calendar" box checked in Settings > Accounts > Google. It will not sync.
Yup... It was not checked and now I had just turn on the check... Does it mean that it is forever gone my appointment ? :(
