Missing Comand process:
623058
Hi
I use advanced task killer, which I have no issues with, but I know there 3 process you need to ignore thus to make sure that every time you all the process it does not stop the Signal on the phone:
Com.Andriod.laucher
Com.Sonyericsson.andriod.friendpivot
The last one I cannot found in the task kill, ( even on low settings)
"Com.Sonyericsson.textinput"
I have looked and its no where to been seen, Im at alost what to do know as that the one I need to get onto the Ignore list.
