Missing contacts numbers
jubatus2013
Hi, guys
I have 400 contacts that i have lost on android repertory.
When i searched forum them i find them, when i enter to contact single page it is like screenshot. I cant mâle normal call but only skype call. When click to edit i find no number like second screenshot. Please help me.
Yes. There are all in my google contacts account. But no number is shown when i see my contact on computer fort exemple.
Make sure you have selected "sync" under settings > accounts > google. If you have your contacts online that should sync them. Hope it helps!
Make sure you have selected 'sync' under settings > accounts > google. If you have your contacts online that should sync them. Hope it helps!
My contacts are lost from Pc and android. But in android i see them on my repertory but when i enter to one contact to see numbers for this contact they is no number in number field. Only number with skype icon and i cant call this number with normal call but only skype voice call. Please see screenshots
My gggguess? Is that you set skype to be your default dialer and that's it entered wrong. You may manually have to go in and change the phone fieild to be in the right place.
