What you need to do is create another one....best way is from the desktop select any app and drag it onto another app which will create a folder. Rename that folder 'favourites' then you can drag anything you like to it as before.
Yeah, as said above. This wasn't something special it was just a folder called favourites, if you can remember what was in the folder then just create a new one and put those apps in there.
