Help Missing LED notifications? Here is a workaround
-Ollie-
[App] NoLED - Use the AMOLED screen for incoming notifications I saw the idea posted somewhere previously that instead of getting the capacitive lights on, we really should be putting the phone's AMOLED screen to work ! specially that it doesn't consume any backlight energy when displaying a black screen. So I developed an app that does just that, upon receiving a notification, it will display a black screen with a dot somewhere in the left top corner. Ok, i really should put these in bullet points..
the application does the following:
1. When your phone receives a notification, it switches the screen on and displays a dot somewhere in the top left corner. The dot bounces around every 3 seconds. This will guarantee using different LEDs so that the same ones won't be burned out !
2. Each type of missed event generates a new LED color. The screen will also display a combination of dots if you missed more than one event. The color scheme is as following:
  • Blue - Missed calls
  • Green - SMS calls
  • Yellow - Gtalk messages
  • Purple - Gmail messages
  • Red - all others (see 3.)
3. NoLED will work with SMS, Gtalk, Gmail and Missed calls even in silent/vibrate mode. However, other apps that may be using audio notifications will not work if phone is in silent/vibrate mode.
4. For all other apps that may be sounding a notification (e.g. some sports apps' notifications), please make sure they only use the default samsung notifications or the ones placed in /sdcard/sd/media/audio/notifications
5. The app runs as a service, after installing, you have two ways to activate the app. (a) by restarting. (b) by loading the widget into your home screen and clicking on it.
3. To get rid of the notification screen, the only key you can use is the home key. Using the capacitive touch buttons will do nothing, and so as clicking anywhere on the screen. Once your screen turns on, all notifications disappear and will not come up until a new notification sound is received.
I have also logged the touch drivers and saw that although I'm displaying a black screen and setting flags to not respond to touch messages, android is still receiving touch messages when you touch any spot on the screen. This, I imagine, consumes resources! So I disabled the touch drivers when the black screen is active. Pressing on the Home button should reactivate it. If your screen is unresponsive to touch even after the notification screen is dismissed, a simple restart should take care of it. Once you've restarted, you can uninstall the app.
Now the touchscreen drivers were a lot easier to mess around with. The sourcecode given by samsung helped me achieve the activation/deactivation of the screen. Things are not the same with the capacitive buttons. You'll notice that when the black screen is on, if you touch any of the soft buttons, they'll light up (although am suppressing them programatically). Am still analyzing the drivers to see if there is an easy way to disable these drivers too when the notification is on.
I just want to let you guys know that this is a beta app. Install it at your own risk.
Enjoy ! Comments and feedback will be appreciated
Update 8/11/2010: Application is now on the Android Market.
If you like this work and want to motivate and encourage further development, please consider a donation
Thanks
[App] NoLED - Use the AMOLED screen for incoming notifications - xda-developers
Just tried it for calls, SMS and emails. It works fine for SMS and emails, but it doesn't show anything for missed calls (althought it should), at least on my GS.
Let's hope this is work in progress (it is a beta app). As suggested by some members of the xdaforum, it would be nice to have icons instead of dots in the future.
But we always want more, don't we? :D
This is indeed a very nice app.
About icons, i suggested this in the early stage of the development. I even made a sample white envelope icon. >.< But because the different LED's in AMOLED have seperate lifespans, and can get dimmer if they stay on for a very long time, they went for randomly placed dots instead of icons.
Thanks for the explanation!
Well, we can't have it all. I am already very happy with the dot system, it is a huge help!
Problem with the application is that it keeps the phone out of standby mode even if its just powering a few pixels.
I read in the xda thread that someone estimated the battery use to 6% (I guess it is +6% compare to the normal standby mode?). Not sure how this person came up with this figure.
For some reasons, the missed call "dot" is now displayed immediately. I haven't changed anything in between (I might have rebooted the phone).
