Missing3 game help forum
combine the oil & additive. Go to item screen and press detail to view the item. Shake the phone several times. It will vibrate a few times sround every 3-5secs. Keep shaking until vibrating stops. Go to the fuel tank on the generator and use the oil. Press the red button then go to the circuit breaker.
I'm stuck at this point. Help is appreciated
can anyone help me on the generator part.....i put the oil in it did the puzzl md pushd the red button wats next???? Please help me!!:(
What does the drawing on the wall means?!!!! :confused
Use spray on wall and the painting will show a 4 digit number. Needed later on to exit this room.
But first solve 5 and 8 LEDs on energy board. Hint: consider the two notes at the immovable switches at the end of the power cords
Ok now im stuck on da part wit the girl in da room wit da red board puzzle nd da boy wit da green numba puzzle dats on da door in the control room
I'm in lab now.
just small hint, the solution is not to activate all three lamps in the same time (remember the video sequence when exiting the last room)
for green number riddle in control room, look at deltas between numbers:
row 1: 7, 7, x, 21, 35 (a bit guessing, between 7 and 21 :-))
row 2: 1, x, 9, 27, 81 (x^0, x^1, x^2...)
row 3: 8, 17, 35, x, 98 (just continue the 8, 17, 35 sequence)
I'm stuck now on red ruby- and blue sapphire boards.
I'm stuck on the red and blue puzzle too. I am suspecting you have to overlap both help pattern to have some part of the solution.
I also realised that when you hide some square and press check they appear on the other colored puzzle but I have no idea what to do from here
Ok i think u have to make all the blue ones nd den push check den switch to da girl so dem blue ones appear on da red one nd make it look lik the pattern ....imma try it but 2mah doe nd let yall kno wats up :)
got it! I'm out :-D
As lclaracq pointed out, you have to draw a picture with both patterns overlapping (e.g. in Excel). Use different colors to still see which line in the pattern was from blue and which was from red pattern (don't mind the few overlapping lines). Then you will get cells (in Excel) with surround blue and red lines.
Next, take the blue and red knots (the buttons) and put them in these cells, always have a blue knot where blue cell borders are, and a red knot next to red borders.
When you have done that you should see 2 characters and 2 numbers in the Excel (I can put that here if you like, but I thought you would like some trying first?)
one more hint: if the solution doesn't work on first try, try to enter it exactly the other way round...
cool game!
thanks to you kiarnac and lclaracq for playing!
when comes missing4? :-)
Wat do the picture look lik that i have to draw?? Im still lost :/
here it comes:
blue puzzle (87):
- 1 2 3 4 5 6 7 8
1 - - - - x x x x
2 - x x - x - - x
3 x - - x - - - x
4 x - - x - - x -
5 - x x - - - x -
6 x - - x - - x -
7 x - - x - - x -
8 - x x - - - - -
red puzzle (SD):
- 1 2 3 4 5 6 7 8
1 - x x - - - - -
2 x - - x - - - -
3 - x - - x x x -
4 - - x - x - - x
5 x - - x x - - x
6 - x x - x - - x
7 - - - - x - - x
8 - - - - x x x -
Help in lab room. have compass, book, rope, water, draw key, book and charger. Don't know what to do with anything.
How to get remote, how to turn on computer, how to slide bookcase etc?
Help!!! I'm stuck in the room wit the generator! I done the oil & stuff & did the # grid every different way! Can't get it!
Here is where I am, with the girl I'm in the room with the red picture I put the red gem in now I'm stuck, with the guy I'm in the lab with the water,rope, book, compass and memo, I put the remote in the slot finished the number puzzle and put key in slot now I'm stuck any help would be fine thanks
Passed this part, I now need code for door behind shelf, I'm thinking the calendar has something to do with it but for now I'm stumped
How do u do puzzle wit green, blue and yellow circuit board in control room:eek:
Its only used for unlocking certain doors , the yellow beam goes to yellow light etc, the doors they open are the lab, control room and power room its pretty easy you can tell which door is open by leaving the room and check the map the shutters should be open or closed depending on which light is on..... If you figure out the code for the door behind the shelf let me know
