Root MIUI Bluetooth question.
nshaw75
I have just changed from cyanogenmod 7 to MIUI 2.3.16. I just fancied a change. One function on the cm7 which I am struggling to achieve with the MIUI is I want the Bluetooth to turn on automatically when I plug in the power cable. Does anybody know if there is a setting already built in, or a suitable app for this?
There's an app in the market that turns bt on and off every time a connected device is switched off/no . Not exactly what you're after but similar.
