MIUI: is there a way to disable the lockscreen (but leaving a pattern or pin code)
cdl
I have MIUI 1.11.11 downloaded from MIUI, Redefining Android – MIUI Android Developers
Is there a way to disable the lockscreen but set a pin or pattern lock? In other words, I'd like to unlock the screen only with a pattern or pin, rather than by first sliding open the MIUI lockscreen and then entering my pattern.
I tried:
https://market.android.com/details?id=org.jraf.android.nolock&feature=search_result
which doesn't work on MIUI and a pattern, and
https://market.android.com/details?...EsImNvbS5zcGx1bmNoeS5hbmRyb2lkLmtleWd1YXJkIl0.
which unfortunately drains my battery.
This seems to be a common question but I couldn't find an answer...
