Help .mkv delaying between video and audio
Kiroma
Hi.
I searched a lot about this problem i'm having and I didn't found anything.
When I'm playing it normally it begins to delay the video while the audio is normal. It's like video is playing at 0.9x and audio is 1x. After some minutes the difference becomes greater to the point that it's awful.
I tried to play it on my pc and it works normally with Media Player Classic.
Then I tried to convert the video to .mp4 and played on S3 and worked perfectly. But I'd not like to have to convert all my videos to it.
Here is some information by MediaInfo of the file:
General
Unique ID : 185694711074562234831585695220009835086 (0x8BB3801DF7F1E19F99C12F472D309A4E)
Complete name : F:\Naruto\Naruto Shippuuden\12th season\narutoPROJECT_-_Shippuuden_322.mkv
Format : Matroska
Format version : Version 2
File size : 324 MiB
Duration : 23mn 9s
Overall bit rate : 1 956 Kbps
Encoded date : UTC 2013-07-25 13:26:58
Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Attachment : Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes / Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 9s
Nominal bit rate : 1 776 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.080
Writing library : x264 core 120 r2120 0c7dab9
Encoding settings : cabac=1 / ref=6 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=1776 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=3552 / vbv_bufsize=8880 / nal_hrd=none / ip_ratio=1.40 / aq=1:0.60
Default : No
Forced : Yes
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 9s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Compression mode : Lossy
Default : No
Forced : Yes
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Default : Yes
Forced : No
Sorry, it was my mistake.
I thought that MX Player was some kind of converter...
I was trying to play with the normal player of the android.
I'll check out if using this program will solve my problem then I'll reply.
Thank you very much.
