MMi complete
Tahialex
When i chech my account i get MMI complete as result , it does't showing me balance , i need help to solve this problem
Not sure which account you are talking about.. if its your cellphone service provider you should contact them
Call your carrier, they might be able to resolve it.
Check you're sending the correct MMI code to get an account balance for your particular carrier? As MMIs are usually carrier specific. You might have SIM Toolkit on your phone, which is provided by some carrier SIMs, often those have quick access to account balance, top-up, etc.
