Root MMS and SMS Issues/attachments
takk1956
My SMS works but can no longer attach Nothing of it keeps cycling Unable to send. I can Do the ##3282# and get to Edit, This look Normal from what I have Read but the way It looks Is diffrent from what I find Online. I cant find a APN editor that Lets me set it like it shows People List For Boost Mobile. I can Edit MCC: its 310 and I can edit MNC: its 00 (its 2 number restricted) I can Edit DATA profile has Pri.Home(68.28.81.76 & Secdary Home(68.28.89.76) Agents When I see Online setting to change MMS
I did the APN Pro and Set the setting as Listed with It But still get, "Unable to Send.Retrying" in my Notification bar at the top. This all did work when Last used 4/16/14 .
I have a Flashed Evo-4G on Virus Rom called "Infected" I have never Updated Profile just the PRL .
I know its Old But I works as I Have a S3 but I dont Know how to copy (clone) Evo to S3 as there are to many Not Complete ways and Local flashers Talk the Talk but they seem to just talk when I tell them To Clone my Evo over to the S3 Because I just Changing Phone.... just Crap so Evo Works for now.
Help My MMS Problem
Try the settings at Boost Mobile (United States) Internet Settings | TheUnlockr
If that doesn't work, bring the phone into a Sprint store and ask them to check the settings for you, give you a printout of the settings and/or suggest to corporate that they put the settings in the Support section of myboostmobile.com (which I did on their survey when I went there to find the settings for you).
