Where do I go to re download the stock mms. I deleted it and Gosms won't work either for pictures. I want to re install the original and go from there. Where do I start?
Not sure how you deleted it as I believe the stock texting/messaging app is a system app.
Unless you are rooted, in which case it is possible.
Anyhoo, could you have possibly disabled it? If so, you should be able to enable it by going to menu/settings/applications/all...then scroll to the bottom to see all your disabled apps......(depending on what device you have and what Android version you are running)
Otherwise, we would need more information about your device such as carrier, model number, rooted or not, Android version #.
