mms dowloads
Is auto retrieve MMS checked in your texting app settings?
What texting app are you using?
Do you have a good data connection when the mms comes in?
Unable to download MMS is often caused by wrong or missing APN details. Check with your carrier for that.
The APN for the Zmax Pro is difficult to change. I think it can be done and some people here seemed to have success with it. I never had a need to try it.
http://androidforums.com/threads/lose-network-frequently.1056985/#post-7355625
Also the B14 update fixed all of my issues with MMS and group texts w/iPhone users.
Some people had success changing to Textra or Android Message (Google messenger) or other 3rd party texting apps
