Root MMS Fix? (CM 11 4.4.4)
You'll probably need another messaging app... Try Textra.
Also, you'll find better help in the ROMs thread, or at least the rooting forum.
If you are handy with pc and familiar with winrar. use winrar to open rom up in winrar window. now take the boost mobile apn fix zip and exteact its contents to desktop or in to its own folder. now drag the apns.xml that is in the extracted boost apn fix over to the cm11 rom in system/etc now close the winrar window after it has added the apns file. copy to sdcard,reboot to recovery and flash the rom. i think the apn fix zips aren't sticking properly for people. by adding the files directly to the rom you should have full services on boot.
