Root MMS fix DL link?
gothicnerd1033
Well, PACman ROM has a bunch of new features, And I may be going back to it for my daily. It has a TON of fixes, Such as FCs fixed... Camera fixed.. GPS fixed.. etc.. But for some odd reason, MMS isnt working...
I tried to do a search on the forum... But "MMS fix" is too short, And it wont search. Could someone give me a link to it please? :D
Thanks both of you. I couldnt find it anywhere. And yes, I downloaded the most recent 5-31 build. Its got alot more goodies. I just couldnt understand why mms didnt work.
The fix worked though. :D
I haven't flashed it yet, but I assume you needed to select the apns. I'll try sometime today and post my results
There was nothing to select when flashing. It just did whatever it had to do and didnt ask anything. I thought that was weird, Because I coulda swore the last time I flashed PACman.. There was an aroma installer. This time, There wasnt. :confused:
