Was getting mms retrieval errors in Textra. Switched to system and set mms settings and received a couple messages successfully, but then started getting errors again. Any solutions?
Hmm, what version are you on?
Currently I'm on version 3.17 and I believe it updated March 16th.
Or is that when you started the MMS retrieval issue? (March 16)
I got the phone on the 12th...The 16th was the first time I got an mms, so I don't have a 'before the problem' period. Don't remember if there was an update around there.
Got this fixed. Had to set MMSC server (with http://) and proxy port. I don't think I had put in the http bit before, assuming it would know to do that.
