yes my text conversations do appear as u have said in 1 single thread wich was very confusing at 1st but now i have that sorted thanks. The problem i have is my girlfriend sent me a pic of her and her daughter by mms. it comes through in the convo message thread but doesnt save to album for some reason. ive tried everything and cant manage to get it in the album. in the end i had to get her to bluetooth me it. then it saved straight in the album?? very strange eh thanks for the reply and hope u know a soloution.You need to download an app called Handcent SMS which as a little added extra allows you to save MMS to your sd card. If this doesn't appear in your album try also downloading Astro file manager which lets you view your SD card and then you can edit,copy,paste,move etc to move the image to your image file then Album should show it.
OK so I have just used my X10 to send my X8 a picture message. When the image is viewed via Handcent long press on the image and you should get a pop up with various options, select save to SD card and a tiny pop up says Image Saved (or words to that effect). Mine then appeared as the most recent image in my Album.
rose red u r amazin got it sorted now but so much hassle lol thanks for that much appreciated. 1 more question do u knw how to permanently have the the date and time up on my screen when the phone is unlocked not just when it is locked. if you know what i mean![]()
also is there a way to rotate the photos etc do i have to dwnload an app? why do droid make these phones so complicated.
)also now i use handsent app everytime i get a text i have to go to handsent and the original inbox any way around this
