Help MMS problem
I am receiving my new N1 tomorrow and this will either hopefully fix the issue or at least point me in the direction of At&t. If it is the N1's fault then I would suggest calling the tech support # and requesting a new phone, I am hoping that if people have this issue they will make the call and let google know. I will let you know of my results tomorrow night.
thanks let me know :)
Try going to apn setup and using reset to defaults from the menu, fixed same issue for me.
After reading this post I realized I couldnt send or receive mms texts. I had all the settings right and still it just continued telling me it was sending. I called att and they tryed a few things that did not work, but then when they realized they had no info on my phone, the lady told me that sometimes when they deactivate a text plan and then start it again it fixes it. Well it worked and everything is fine now, hope this helps.
The MMS port is network dependant, some don't have one some do. One of the important bits is the APN type which seems to tell the phone to use a given APN for various services such as MMS, so check you have something sensible in there after resetting to defaults. Mine is set to default,supl,mms
i have noticed that i only dont receave mms when there from verizon... i can receave them from at&t and t-mobile from what ive tried
