Help MMS Problem
And after double posting the solution is? From what I can see, to email it instead, which isnt MMS :rolleyes:
so what if i double posted its not a crime it not illegal instead of giving people shit if they have made a mistake why dont you help them, i asked a valid question and if you had bothered to read the thread in the link i posted you would have seen the solution omg.
"Originally Posted by Zappza View Post
It's the operator.
Had the exact same problem when I was in the UK and used O2. When I
returned to Norway and Telenor (which have Android devices) MMS are
sized properly.
The workaround is to use Handcent or chompSMS and change the useragent
to The N95 or the iPhone."
this works for me instead of the images resizing from around 900kb to a poor 16kb when the limit is 300k the images are now resizing at between 150kb to 290kb using Handcent which is fully compatible with the htc desire.
Thank you
