Help MMS problems
mingus76
I'm having trouble sending pics, when I get the msg ready it converts the file from sms to mms but when I send it, it just disappears. Am I doing something wrong?
Messages will convert to MMS is they are very long, or if you're attaching something to it.
Are you saying it does this even on a short text message?
Have you tried other messaging apps?
Give Handcent a try. I like it much better than the stock app, and maybe it'll take care of your problem also.
