MMS Question
markdoc
Android Expert
Does anyone know why, when using a non-stock app, you cannot use wifi for receiving MMS messages. I was told by support for Go SMS and Handcent that you have to use "Mobile Data" for sending and receiving MMS. However, with the stock "Messages" app, I can send and receive them over wifi. :confused:
The stock messages app sends the link for the MMS file via 2G - data, not wifi. (MMS is sent as a URL via text - downloading the MMS file can be done via wifi with some apps, but the initial "text" can't be, due to the fact that the text - the link to the MMS file - has to be sent via 2G. So effectively, both SMS and MMS are limited to data, not wifi.)
If you want to lodge a complaint, it should go to the genius who decided to use a pocket pager protocol as a way of having a two-way conversation (even before MMS was considered). If texting had been designed to ride on an email protocol it would have worked out much better. (If a totally separre protocol had been designed, of course ... but people are basically lazy. "Good enough for the boss to approve is good enough, it's 5 o'clock so let's get out of here.")
Thanks for the answer. If you don't mind, one more.
You said MMS & SMS, but I've never had a problem sending & receiving SMS over wifi. I use optimum wifi most of the time w/o a glitch. (I'm not trying to argue, I just want to learn) :thumbup:
