Hi,
Last week, I stumbled at the seafront. My mobile phone was in my pocket which the water reached to. I pulled out my mob and saw it still on...then got a message u can only make an emergency call and it switched off automatically.
Once home, I could not power it up. Tried to charge the battery when mob was switched off, but there was no indication of battery charging.
I was advised to put the phone in a pack of rice which what I did after removing the battery cover and drying the inside of the phone, there was clear water drops left inside the mobile phone.
After nearly 2 days, i removed the phone from the rice pack; the mobile powered up but did not recognise the sim card which I am able to use on another phone. Also, some buttons actions were irresponsive.
As such, I unscrewed the phone completely, cleaning the motherboard with isopropyl alcohol (91%); then left the phone to dry out. When i switch it on, it powers up for around 40 secs then the screen blacks out completely. My screen touches are not recognised anymore during the initial 40 seconds, I can't input the password to unlock the phone... when i unscrewed the phone, i swept with a toothbrush the area just underneath the screen...may be this action damaged the touch screen command interpreter. any advice, please?
Thank you
Thank you
