Harry2
Extreme Android User
I'm happy with JustMobile Gum Pro as mobile charger for my Desire.
And I wondered for the big amount of posts about Pebble in this forum and so little about JustMobile.
So I decided to have a closer look at the famous Pebble.
And I have to say, I like the features list of Pebble, too. It's a good choose.
Pebble: Li-Ion battery with 5000mAh, input 5V/1000mA, output 5V/ 950mA
JustMobile: Li-Ion battery with 4400mAh, input 5V/1000mA, output 5V/1000mA
Pebble: Weight 138 grams, 100 x 56 x 13 mm
JustMobile: Weight 120 grams, 69 x 54 x 22 mm
Both charger itself are fast charged with 1000mA
Both charger are fast charging the Desire with 1000mA
No worry about capacity: Both charger are charging the Desire about two times.
Charger input.
Pebble: Special socket for cable with special plug to USB
JustMobile: miniUSB socket for standard USB data cable with miniUSB to USB
Charger output.
Pebble: USB socket for cable with special socket + microUSB adaptor to microUSB
JustMobile: USB socket for standard USB data cable with USB to microUSB
About the Pebble adaptors:
You have noticed that you must use this special microUSB adaptor if you want the Desire to charge with 1000mA?
A guy has posted in a Pebble thread that he has lost this special microUSB adaptor.
Since then he uses a standard USB data cable with the Pebble for charging his Desire.
Therefore, the phone takes the double time for charging because it's charging only with "USB" (= 500mA).
My conclusion:
I just love the JustMobile because of its simple input/output design (oh, better would be miroUSB instead of miniUSB as input
No need for special cables/adaptors. I can use the USB data cable from the HTC charger.
And if I want to charge my old SonyEricsson I will use the SE USB data cable.
This is my personal opinion about the Pebble adaptors.
You may see more the universal benefits of this adaptors.
As I said in the beginning of my post: I like the features list of Pebble, too. It's a good choose
Harry
Note: Particularly heavy use of Google Translate
Charger input.
Charger output.
My conclusion:
).No need for special cables/adaptors. I can use the USB data cable from the HTC charger.
Harry
