Help Mobile data doesn't work
On my LG G3, I have Mobile Data switched on but nothing comes up in the info bar at the top of the screen, just bars of signal, and no H,H+,3G,4G. This is the first time I've had this problem since I got the phone in August last year. My Wi-fi works fine, and I noticed this problem about 5-6 hours ago.
EDIT: I have restarted the phone twice, and taken the sim out and put it back in, and it hasn't worked.
WELCOME TO ANDROID FORUMS Louis Beaven ! :thumbsupdroid:
Not knowing which model of G3 or where you got it,I'd start w/checking the compatibility of your phone w/the carrier you're using:
http://www.willmyphonework.net/
If the above isn't an issue,I'd try another SIM Card,&/or try the one you have in another phone to verify that it works.
The above website says there are no problems at all. I've had the same phone and sim for almost a year, brand new from my network (3 UK). It is an LG G3 D855. I'm more than sure the phone is locked, so another sim won't work in it, I suppose I could try it in my old iPhone 4? That will have to wait till tomorrow though, since I don't have it with me.
