EVERYTIME I try to turn on my Mobile Hotspot, it does not trigger on until after I a reboot. It is very annoying that I have to wait several minutes of turning off then back on before I can use this feature.
I used the Mobile Hotspot feature on mine as long as the "free trial" lasted and didn't have any problem or need to reboot. (It sure does take battery power, though.)
I have the same problem about 80% of the time. It usually happens to me if I have used the MHS feature earlier in the day and try to use it again. I put up with it...what choice do I really have.
