Help Mobile hotspot "stuck"
Larry_ok
Yesterday I tried to turn on my mobile hotspot and it got "stuck" turning on (see attached photo). It has worked find for over a year until now. I have turned off the phone many times and it still is like this. Anyone have a fix for this?
Thanks!
Hello Larry and welcome to AF. You might try following the restart option vs the power off option the next time you shut down your M8. Your problem is likely software related and this could be a fix. If not, a possible factory reset might be your avenue. Good luck
